asobeih
Directory for.txt Simulation Files
I am running a testbench, which gets the inputs and passes the out to different associated .txt files.
When I run the simulation on Vivado 2015.4, I get this error that the specified files are not found.
I would like to inquire about the right directory, in which I have to put these files so that, the simulator can use them in the simulation.
Thanks!
srimaye
Hi @asobeih,
Can you add the .txt files in simulation sources? Under source window , right click on simulation sources and add the files to the project. You can see them as text files under simulation sources after adding.
Srimayee
srimaye
Hi @asobeih,
Srimayee
