Does Vivado simulator in 2020.1 support tracing variables
I have a very simple simulation and cannot see variables from my top level test bench, even though enabled in the GUI!  Is this not supported?
process(clk)
    variable count1: integer := 0;
    variable count2: integer := 0;
begin
   if rising_edge(clk)then
       if (count1 < 10) then
           count1 := count1 + 1;
           reset <= '0';
     elsif (count2 < 10) then
         count2 := count2 + 1;
         reset <= '1';
    else
        reset <= '0';
    end if;
end if;
end process;
It is supported. Please select 'VHDL Process' from scope window.
Harika.
Is it also possible to display a VHDL variable in the waveform window? When I right-click a variable, the "Add to waveform window" option is greyed out. For signals, it works fine.
Vivado Simulator does not yet support tracing of VHDL variables.
Harika.
No it doesn't. The add to wave for is greyed out when you select it. This is really lame. Is it expected to support this in the future? What is the best workaround - buy a 3rd party tool?
welcome to the world of Xilinx lack of support for VHDL .
This has been asked for many years
but the ears dont seem to hear.
Its not like all other simulators have had this ability for years
