syouyu2001
Dynamic Range in Linear Array
I did codeing with "reg [dwidth-1:0] data [255:0];" for preparation of input data, and I modified it to linear array as "reg [dwidth*256-1:0] data;" then I need a dynamic range such as data[msb:lsb] with equations of msb and lsb in a task in testbench. But VIvado makes error of that it needs a constant range.
How to manipulate dynamic range in the task?
SYOUYU
syouyu2001
When the task is replaced with initial begin ~ end, error message describes that bsb and lsb are not declared. This might I do not understand a syntax in a simulation.
martin.rognerud
I'm not sure I understand what you asking for but is this what you are looking for?
https://stackoverflow.com/questions/18067571/indexing-vectors-and-arrays-with
syouyu2001
Hi martin.rognerud,
Thank you very much, that is answer.
Best,
SYOUYU
bandi
Hi @syouyu2001,
If your query is addressed then can you please close the thread by marking the post which helped you as accepted solution.
Thanks & Regards,
Sravanthi B
Please mark the appropriate answer as "Accept as solution" if information provided is helpful.
Give 'Kudos' to a post which you think is useful and reply oriented.
Thanks & Regards,
Sravanthi B
