Behrouz
EDF File Export Failed
I updated dSPACE and Xilinx to 2015.2 version. Now, I faced with an error during FPGA build process. Following is the error message:
The EDF export of the results of the Xilinx System Generator build failed.
C:\Last Version LTC Engine\Allengine68_rtiFPGA\FPGA_Test_77F62F510F2A68\sysgen\hdl_netlist\vivado.log
I checked the storage space and I have 4.2 GB available storage at C drive. This means that I have enough space to write the EDIF file. On the other hand, storage folder path has 90 characters which is below 260 maximum acceptable length.
Would you please help me to find the reason for this error and fix it.
I am attaching "vivado.log", "VivadoEDFExportConsoleOutput.log" and "VivadoSynthConsoleOutput.log" files to this help request.
Thanks in advance for your help.
Behrouz
barriet
I'd try it without a space in the path... From your "VivadoEDFExportConsoleOutput.log", it looks like write_edif might be using the path as-is (not escaped) and the TCL interpreter could be seeing this as a command line separator.
Personally I always try to avoid spaces in directory and file names as weird issues like this can come up with you least expect it.
barriet
For example, try renaming "Last Version LTC Engine" to "Last_Version_LTC_Engine" on the root of your C volume
Behrouz
Thank you very much for your solution. It solved the problem. I removed spaces from the file name and I could compile the model without facing any error.
Thanks again for your help.
barriet
Thanks for the update - I'm glad to hear that it fixed the issue.
