Visitor mgoubert
ERROR:Simulator:861 - Failed to link the design (ubuntu 12.04)
i know ubuntu is not supported by xilinx, but i was wondering if annyone new the solution for the following problem.
Started : "Simulate Behavioral Model".
Determining files marked for global include in the design...
Running fuse...
Command Line: fuse -intstyle ise -incremental -lib secureip -o /home/matthias/Documents/EAICT20122013/Thesis/xilinx/xtm640/xtm640.prj/xtm640_tb_isim_beh.exe -prj /home/matthias/Documents/EAICT20122013/Thesis/xilinx/xtm640/xtm640.prj/xtm640_tb_beh.prj work.xtm640_tb {}
Running: /opt/Xilinx/14.4/ISE_DS/ISE/bin/lin64/unwrapped/fuse -intstyle ise -incremental -lib secureip -o /home/matthias/Documents/EAICT20122013/Thesis/xilinx/xtm640/xtm640.prj/xtm640_tb_isim_beh.exe -prj /home/matthias/Documents/EAICT20122013/Thesis/xilinx/xtm640/xtm640.prj/xtm640_tb_beh.prj work.xtm640_tb
ISim P.49d (signature 0xfbc00daa)
Number of CPUs detected in this system: 2
Turning on mult-threading, number of parallel sub-compilation jobs: 4
Determining compilation order of HDL files
Parsing VHDL file "/home/matthias/Documents/EAICT20122013/Thesis/xilinx/xtm640/xtm640.prj/xtm640.vhd" into library work
Parsing VHDL file "/home/matthias/Documents/EAICT20122013/Thesis/xilinx/xtm640/xtm640.prj/xtm640_tb.vhd" into library work
Starting static elaboration
Completed static elaboration
Fuse Memory Usage: 94944 KB
Fuse CPU Usage: 1680 ms
Compiling package standard
Compiling package std_logic_1164
Compiling architecture behavioral of entity xtm640 [xtm640_default]
Compiling architecture behavior of entity xtm640_tb
Time Resolution for simulation is 1ps.
Process "Simulate Behavioral Model" failed
Previous problems with xilinx i could solve by linking the right libraries. But here i don't get a lot of erros, just ERROR:Simulator:861 - Failed to link the design!
Can someone point me in the right direction, or knows the solution?
Ty
Visitor mgoubert
Re: ERROR:Simulator:861 - Failed to link the design (ubuntu 12.04)
Forgot to mention : I am using vivado 14.4
Visitor tmiron23
I'm using version 14.5 and have the same problem. from what I read before about this problem, if you are using windows 8, it might  not support it.
Participant jairoscz
Were you able to resolve this issue?
The first thing to do with this situation is to add "-mt off -v" to the "Other Compiler Options"  line in "Process Properties"  for the simulator. (Check that the "display level" is set to "advanced" if you can't find it)
This will give you better information about what went wrong.
In my case, the linker reported
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.7/libgcc.a when searching for -lgcc
/usr/bin/ld: cannot find -lgcc
because Webpack insists on being 32-bit even on a 64-bit system, and I didn't have the 32-bit version of libgcc available.
On Debian (Wheeze or Testing) the solution was to add the missing libraries (there were others!)
sudo apt-get -t testing install ia32-libs
sudo apt-get -t testing install gcc-multilib
worked for me, and Ubuntu will be similar.
Whether they are correct for you will depend on your system and the actual linker error : if it is different, post it here...
