ERROR: [VRFC 10-1537] value 0 is out of target constraint range 1 to 2147483647
I got the above error while trying to simulate my design. Does anyone know what this error is about? The portion of the code is below. The error points to the last line. I am using Vivado 2015.2. Thank you.
-- MEM_DECODE_GEN: Universal Address Decode Block
MEM_DECODE_GEN: for bar_index in 0 to NUM_BASE_ADDRS-1 generate
constant CE_INDEX_START : integer
                        := calc_start_ce_index(C_ARD_NUM_CE_ARRAY,bar_index);
constant CE_ADDR_SIZE   : Integer range 0 to 15
                        := clog2(C_ARD_NUM_CE_ARRAY(bar_index));                            <---- Error points to this line
Professor
Professor
clog2 expects a non-zero positive integer.  (What's the log of zero?)
Apparently your expression C_ARD_NUM_CE_ARRAY(bar_index) evaluates to zero.
-- Gabor
