Observer waidcsuf
ERROR: [Vivado 12-3591] compile_simlib failed to compile for questasim with 5 errors
I have Questa 10.5c and Vivado 2016.4.  When I attempt to compile simulation libraries I get 5 errors.
compile_simlib -force -language all -dir {C:/questa_10.5c_Vivado_2016.4_lib} -simulator questa -simulator_exec_path {C:/questasim64_10.5c/win64} -verbose  -library unisim -family  virtex7 -family  artix7
Compiling vhdl library 'v_st2059'...Executing cmd 'C:\questasim64_10.5c\win64/vcom  -64 -93 -work v_st2059 -f C:\questa_10.5c_Vivado_2016.4_lib/v_st2059/.cxl.vhdl.v_st2059.v_st2059.nt64.cmf' with output 'C:\questa_10.5c_Vivado_2016.4_lib/v_st2059/.cxl.vhdl.v_st2059.v_st2059.nt64.log' (Wed Feb 07 11:14:50 2018)...
compile_simlib[exe]: The command line 'C:\questasim64_10.5c\win64/vcom  -64 -93 -work v_st2059 -f C:\questa_10.5c_Vivado_2016.4_lib/v_st2059/.cxl.vhdl.v_st2059.v_st2059.nt64.cmf' returned exit code '2'.
Reading the cxl log file - 'C:\questa_10.5c_Vivado_2016.4_lib/v_st2059/.cxl.vhdl.v_st2059.v_st2059.nt64.log' for warnings...
Generating the cxl result file - 'C:\questa_10.5c_Vivado_2016.4_lib/v_st2059/.cxl.vhdl.v_st2059.v_st2059.nt64.rpt' ...
compile_simlib: 1 error(s), 1 warning(s), 34.05 % complete
Compiling vhdl library 'axi_ethernetlite_v3_0_9'...Executing cmd 'C:\questasim64_10.5c\win64/vcom  -64 -93 -work axi_ethernetlite_v3_0_9 -f C:\questa_10.5c_Vivado_2016.4_lib/axi_ethernetlite_v3_0_9/.cxl.vhdl.axi_ethernetlite_v3_0_9.axi_ethernetlite_v3_0_9.nt64.cmf' with output 'C:\questa_10.5c_Vivado_2016.4_lib/axi_ethernetlite_v3_0_9/.cxl.vhdl.axi_ethernetlite_v3_0_9.axi_ethernetlite_v3_0_9.nt64.log' (Wed Feb 07 11:14:50 2018)...
compile_simlib[exe]: The command line 'C:\questasim64_10.5c\win64/vcom  -64 -93 -work axi_ethernetlite_v3_0_9 -f C:\questa_10.5c_Vivado_2016.4_lib/axi_ethernetlite_v3_0_9/.cxl.vhdl.axi_ethernetlite_v3_0_9.axi_ethernetlite_v3_0_9.nt64.cmf' returned exit code '2'.
Reading the cxl log file - 'C:\questa_10.5c_Vivado_2016.4_lib/axi_ethernetlite_v3_0_9/.cxl.vhdl.axi_ethernetlite_v3_0_9.axi_ethernetlite_v3_0_9.nt64.log' for warnings...
Generating the cxl result file - 'C:\questa_10.5c_Vivado_2016.4_lib/axi_ethernetlite_v3_0_9/.cxl.vhdl.axi_ethernetlite_v3_0_9.axi_ethernetlite_v3_0_9.nt64.rpt' ...
compile_simlib: 1 error(s), 1 warning(s), 50.90 % complete
Compiling vhdl library 'axi_quad_spi_v3_2_10'...Executing cmd 'C:\questasim64_10.5c\win64/vcom  -64 -93 -work axi_quad_spi_v3_2_10 -f C:\questa_10.5c_Vivado_2016.4_lib/axi_quad_spi_v3_2_10/.cxl.vhdl.axi_quad_spi_v3_2_10.axi_quad_spi_v3_2_10.nt64.cmf' with output 'C:\questa_10.5c_Vivado_2016.4_lib/axi_quad_spi_v3_2_10/.cxl.vhdl.axi_quad_spi_v3_2_10.axi_quad_spi_v3_2_10.nt64.log' (Wed Feb 07 11:14:50 2018)...
compile_simlib[exe]: The command line 'C:\questasim64_10.5c\win64/vcom  -64 -93 -work axi_quad_spi_v3_2_10 -f C:\questa_10.5c_Vivado_2016.4_lib/axi_quad_spi_v3_2_10/.cxl.vhdl.axi_quad_spi_v3_2_10.axi_quad_spi_v3_2_10.nt64.cmf' returned exit code '2'.
Reading the cxl log file - 'C:\questa_10.5c_Vivado_2016.4_lib/axi_quad_spi_v3_2_10/.cxl.vhdl.axi_quad_spi_v3_2_10.axi_quad_spi_v3_2_10.nt64.log' for warnings...
Generating the cxl result file - 'C:\questa_10.5c_Vivado_2016.4_lib/axi_quad_spi_v3_2_10/.cxl.vhdl.axi_quad_spi_v3_2_10.axi_quad_spi_v3_2_10.nt64.rpt' ...
compile_simlib: 1 error(s), 4 warning(s), 56.27 % complete
Compiling vhdl library 'axi_vdma_v6_2_10'...Executing cmd 'C:\questasim64_10.5c\win64/vcom  -64 -93 -work axi_vdma_v6_2_10 -f C:\questa_10.5c_Vivado_2016.4_lib/axi_vdma_v6_2_10/.cxl.vhdl.axi_vdma_v6_2_10.axi_vdma_v6_2_10.nt64.cmf' with output 'C:\questa_10.5c_Vivado_2016.4_lib/axi_vdma_v6_2_10/.cxl.vhdl.axi_vdma_v6_2_10.axi_vdma_v6_2_10.nt64.log' (Wed Feb 07 11:14:50 2018)...
compile_simlib[exe]: The command line 'C:\questasim64_10.5c\win64/vcom  -64 -93 -work axi_vdma_v6_2_10 -f C:\questa_10.5c_Vivado_2016.4_lib/axi_vdma_v6_2_10/.cxl.vhdl.axi_vdma_v6_2_10.axi_vdma_v6_2_10.nt64.cmf' returned exit code '2'.
Reading the cxl log file - 'C:\questa_10.5c_Vivado_2016.4_lib/axi_vdma_v6_2_10/.cxl.vhdl.axi_vdma_v6_2_10.axi_vdma_v6_2_10.nt64.log' for warnings...
Generating the cxl result file - 'C:\questa_10.5c_Vivado_2016.4_lib/axi_vdma_v6_2_10/.cxl.vhdl.axi_vdma_v6_2_10.axi_vdma_v6_2_10.nt64.rpt' ...
compile_simlib: 1 error(s), 1 warning(s), 60.57 % complete
Compiling vhdl library 'cpri_v8_7_1'...Executing cmd 'C:\questasim64_10.5c\win64/vcom  -64 -93 -work cpri_v8_7_1 -f C:\questa_10.5c_Vivado_2016.4_lib/cpri_v8_7_1/.cxl.vhdl.cpri_v8_7_1.cpri_v8_7_1.nt64.cmf' with output 'C:\questa_10.5c_Vivado_2016.4_lib/cpri_v8_7_1/.cxl.vhdl.cpri_v8_7_1.cpri_v8_7_1.nt64.log' (Wed Feb 07 11:14:50 2018)...
compile_simlib[exe]: The command line 'C:\questasim64_10.5c\win64/vcom  -64 -93 -work cpri_v8_7_1 -f C:\questa_10.5c_Vivado_2016.4_lib/cpri_v8_7_1/.cxl.vhdl.cpri_v8_7_1.cpri_v8_7_1.nt64.cmf' returned exit code '2'.
Reading the cxl log file - 'C:\questa_10.5c_Vivado_2016.4_lib/cpri_v8_7_1/.cxl.vhdl.cpri_v8_7_1.cpri_v8_7_1.nt64.log' for warnings...
Generating the cxl result file - 'C:\questa_10.5c_Vivado_2016.4_lib/cpri_v8_7_1/.cxl.vhdl.cpri_v8_7_1.cpri_v8_7_1.nt64.rpt' ...
compile_simlib: 1 error(s), 1 warning(s), 69.18 % complete
Observer waidcsuf
Re: ERROR: [Vivado 12-3591] compile_simlib failed to compile for questasim with 5 errors
Well I have no idea what changed that cleared up the errors.
Mentor.com has confirmed the warnings can be ignored.
Mentor -
"As long as you are compiling in 64 bit installed version, you should not worry about this warning.
This warning will not be creating any issue. You may ignore this warning."
I am going to mark this as solved even though it seems to have cleared up for no known reason.
Hi @waidcsuf,
Can you please share the compile_simlib.log and vivado.log files to check. Also please share the below log files.
Can you please try compiling with the below command and check if this helps:
compile_simlib -language all -dir {C:/sravanthiB/test_questa} -simulator questa -simulator_exec_path {C:/questa/10.5c/bin} -verbose  -library all -family  all
Thanks & Regards,
Sravanthi B
Thanks & Regards,
Sravanthi B
Observer waidcsuf
Sravanthi,
Thank you for helping.
I can't share the compile_simlib.log and vivado.log files because I don't know where to find them.  I can not find anything in the tcl console that indicates that a compile_simlib.log or a vivado.log file are created/saved.  If you can point me in the right direction, I will try to locate the log's and share them.
I started the compile sim lib process again last night and this morning it appears to have finished with no errors.  I still get at least 1 or more warnings on all items compiled but no errors. Does this mean success?  There are two things that I did differently this time.
1. When the compilation failed, all attempts where made from the compile simulation libraries gui window, accessed from the Vivado start page.  I had no project open.
2. All of the failed attempts where pointed to an existing, empty, directory to store the output.
For the "successful" attempt,( I still have warnings on everything) I accessed the compile simulation library GUI from within an open project and the path set to save the compilation output was to a non-existing directory.
Does this give any clues?
Hi @waidcsuf,
The log files will be generated in the working directory. can you please type "pwd" in vivado TCL console to know the location.
Can you please make sure that it shows zero errors in summary as shown below:
Can you please refer and confirm that you have followed the steps mentioned in the below Answer Record:
https://www.xilinx.com/support/answers/64083.html
Thanks & Regards,
Sravanthi B
Thanks & Regards,
Sravanthi B
Observer waidcsuf
Maybe this helps.
In the target directory for the compiled library location I have hundreds of folders, one fore each compiled item.  There is a log file in each folder.  Upon inspecting a few I see a common warning in each.
** Warning: (vcom-159) Mode option -64 is not supported in this context and will be ignored.
I running 64 bit Win7, Questa Sim -64 10.5c, and Vivado 2016.4.(64-bit).
Observer waidcsuf
Sravanthi
The log files were located where you said they would be.  I have attached them.
I can confirm 0 errors on my latest attempt at library compilation.
I read the answer record https://www.xilinx.com/support/answers/64083.html
It appears to state a very simple process which I have followed.  I am using the GUI compile simulation window method in all attempts.
Observer waidcsuf
Mentor -
