pgigliotti_usac
ERROR: [XSIM 43-3294] Signal EXCEPTION_ACCESS_VIOLATION received.
I am using Vivado 2020.1 tools to simulate my design.  All source files are of type VHDL-2008.
I am trying to look at a lower level signal to gate activities in my top level testbench.
I have added the following alias, signals and code, which causes the above error message
alias Data_from_CTL_empty is <<signal Inst_VMUX_Top.Inst_Switch_IF.Data_from_CTL_empty : std_logic>>;
signal SW_from_CTL_empty_rising: boolean;
signal Clear_Data_from_CTL_empty : boolean;
process(sys_reset, Data_from_CTL_empty, Clear_Data_from_CTL_empty);begin
    if(sys_reset = '1') then
          SW_from_CTL_empty_rising <= false;
    elsif(rising_edge(Data_from_CTL_empty)) then
          SW_from_CTL_empty_rising <= true;
    elsif(Clear_Data_from_CTL_empty = true)then
     end if;
end process;
Any toought (other than move to questa).
richardhead
Without the full code so the problem can be re-created, it will be very difficult to comment.
But I would recommend a move to questa even without the crash.
pgigliotti_usac
Well, if I remove everything but the alias. It runs without issue.  Yes, this Vivado simulator is not all that great.  One thing that I really dislike is that it cannot display variables in the waveform viewer.  I have lost numerous hours going back into my code adding debug signals, since I cannot track the value of variables. A serious short-coming of this tool.
Regarding Questa, we are in the process working with our IT department to get it installed. Another pain in my life.
pgigliotti_usac
BTW, I was a Xilinx FAE a while back and we used to keep a cube in San Jose  open for FAEs, and it had a name plate Richard Cranium on the wall. Just saying.
bandi
Hi @pgigliotti_usac ,
Can you please share a test case to reproduce and check this issue at our end.
Thanks & Regards,
Sravanthi B
