ERROR: [XSIM 43-3356] Could not open file xsim.type file for writing
HI , I'm using 2016.2 almost from 1 yr , but I never faced like this error while simulating my code.
I'm getting error like (got to see in elaborate.log) this
ERROR: [XSIM 43-3356] Could not open file xsim.dir/tb_DSS_SPI_mst_behav/xsim.type for writing.
ERROR: [XSIM 43-3915] Encountered a fatal error. Cannot continue. Exiting...
kindly tell me ASAP why this is happening and how to resolve it.
Thank you
Lalith kumar
attached: elaborate.log file.
Hi @lalithkumar,
Can you try ending the xsimk.exe process in Task manager and then try re-running the simulation?
Thanks & Regards,
Prathik
Hi @lalithkumar,
Thanks & Regards,
Prathik
