Elapsed simulation time is much higher than CPU time
I'm trying to speed up my simulation, I'm using -mt flags and all, and I've payed attention, that after simulation ends, the elapsed time (the real time of simulation run) is much higher than CPU time, although I see CPU is 100% utilized during the run.
I'm using linux64, 16 cores, 64GB memory.
Am I missing something? What could be the reason for that?
Example1:
run: Time (s): cpu = 00:12:36 ; elapsed = 01:09:35 . Memory (MB): peak = 5149.230 ; gain = 309.867
Example2:
run: Time (s): cpu = 00:12:06 ; elapsed = 01:03:07 . Memory (MB): peak = 6166.566 ; gain = 0.000
Example3:
run: Time (s): cpu = 00:04:23 ; elapsed = 00:38:57 . Memory (MB): peak = 4945.793 ; gain = 117.945
Re: Elapsed simulation time is much higher than CPU time
I am facing the same situation
run: Time (s): cpu = 00:49:36 ; elapsed = 15:11:46 . Memory (MB): peak = 8125.973 ; gain = 379.031 ; free physical = 7436 ; free virtual = 31083
Any Idea of the possible cause for this low performance?
I am running an 8 cores system, with 32GB of mem
Not all the memory is being used, and
I tried forcing "-mt" option in simulation options, but it has no effect, and only one processor is working the other are iddle...
%Cpu0 : 2.3 usuario, 0.7 sist, 0.0 adecuado, 96.7 inact, 0.3 en espera, 0.0 hardw int, 0.0 softw int, 0.0 robar tiempo
%Cpu1 : 2.6 usuario, 1.0 sist, 0.0 adecuado, 95.7 inact, 0.7 en espera, 0.0 hardw int, 0.0 softw int, 0.0 robar tiempo
%Cpu2 : 4.6 usuario, 0.7 sist, 0.0 adecuado, 94.7 inact, 0.0 en espera, 0.0 hardw int, 0.0 softw int, 0.0 robar tiempo
%Cpu3 : 0.0 usuario, 0.0 sist, 0.0 adecuado,100.0 inact, 0.0 en espera, 0.0 hardw int, 0.0 softw int, 0.0 robar tiempo
%Cpu4 : 1.6 usuario, 3.2 sist, 0.0 adecuado, 94.5 inact, 0.6 en espera, 0.0 hardw int, 0.0 softw int, 0.0 robar tiempo
%Cpu5 : 1.3 usuario, 0.3 sist, 0.0 adecuado, 98.3 inact, 0.0 en espera, 0.0 hardw int, 0.0 softw int, 0.0 robar tiempo
%Cpu6 : 2.6 usuario, 0.7 sist, 0.0 adecuado, 96.7 inact, 0.0 en espera, 0.0 hardw int, 0.0 softw int, 0.0 robar tiempo
%Cpu7 :100.0 usuario, 0.0 sist, 0.0 adecuado, 0.0 inact, 0.0 en espera, 0.0 hardw int, 0.0 softw int, 0.0 robar tiempo
KiB Mem : 32889376 total, 7172868 free, 8039600 used, 17676908 buff/cache
Hi @jomarm10
Are you facing this issue specific to simulation or other Vivado applications as well?
Check this AR https://www.xilinx.com/support/answers/56840.html
As per me, one reason of  the possible  elapsed time going very high could be that you have network installation and you are accessing  the files from your local disk. I have seen this issue in Vivado with Windows network installation.
Rohit
Rohit
This low performance is only for the simulation.
All files are local, only Vivado license server is placed in a remote server,
I am running vivado 2016.2 under an Ubuntu 16.04 LTS
Hi @jomarm10
Ubuntu 16.04 LTS is not a supported OS for Vivado 2016.2 which you are using. Such undeterministic results are seen when unsupported OS is used as you mention that the issue is with simulation only.  Can you please use supported OS and see if you face same issue. Please refer the below link, page 8  for information regarding supported OS for 2016.2:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug973-vivado-release-notes-install-license.pdf
Parallely you can also try with the following and see if it helps:
1) Try changing -mt option to value other than auto.
2) Also to speed up simulation run time,  use Fast Model by Enabling the fast sim models in Sim properties. Please refer the below link,page 22 for information  on this.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug900-vivado-logic-simulation.pdf
Hope the shared information will be useful. Please note that use of supported OS is must for the Vivado verison you are using as per Xilinx.
Rohit
Rohit
Hi @thakurr
Ok, I see that ubuntu 14.03 is the one that is supported. I will check if we can go back to that version.
In the meantime,
I already tried both tips, with dispair results.
Forcing "-mt" to a fixed value has no effect .
Enabling FASTSIM works,
  set_property unifast true [current_fileset sim_1]
improving simulation elapsed time between a 15% to 20%.
Thank you.
jose
Jose
I installed Vivado 2016.4, that supports Ubuntu 16.04 LTS
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug973-vivado-release-notes-install-license.pdf
but the numbers are very similar (a little bit worse)
run: Time (s): cpu = 00:00:21 ; elapsed = 00:06:02 . Memory (MB): peak = 6986.918 ; gain = 0.000 ; free physical = 17318 ; free virtual = 28580
