Visitor julien-niu
Encounter an error when trying to call c function sin()
I try to use a c function sin() in testbench written in systemVerilog. However, when I start the simulation, it throws an error like this: "Vivado Simulator kernel has encounted an exception from DPI C function: cos(). Please correct."
Here is the relevant code:
package math_pkg;
  // import functions directly from C library
  //import dpi task      C Name = SV function name
  import "DPI-C" pure function real cos(input real rTheta);
  import "DPI-C" pure function real sin(input real y);
  import "DPI-C" pure function real atan2(input real y, input real x);
endpackage : math_pkg
 wr = math_pkg::cos(theta);
 wi = math_pkg::sin(theta);
Does anyone know what else I need to setup in order to successfully use a built-in c library?
Re: Encounter an error when trying to call c function sin()
Hi @julien-niu ,
Have a look at Appendix D of User Guide 900, it has information on using DPI and compiling C Code.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug900-vivado-logic-simulation.pdf#G13.393986
At this time it only works via scripting and not via the GUI
You can generate scripts to modify by using the export_simulation tcl command.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
