fsabbari
Erors while compiling libraries for Modelsim 10.7 on Vivado 2017.3
I am trying to compile libraries for Modelsim 10.7 on Vivado 2017.3 and I am getting this errors :
Library 'xdma_v4_0_0' compilation error(s)
** Warning: (vlog-159) Mode option -32 is not supported in this context and will be ignored.
Model Technology ModelSim PE vlog 10.5a Compiler 2016.04 Apr  5 2016
Start time: 18:26:06 on May 09,2020
vlog -32 -L xdma_v4_0_0 "+incdir+C:\Users\sab\AppData\Roaming\Xilinx\Vivado\.cxl.ip/incl" -sv -work xdma_v4_0_0 -f C:\compiled/xdma_v4_0_0/.cxl.systemverilog.xdma_v4_0_0.xdma_v4_0_0.nt64.cmf
** Warning: C:/Xilinx/Vivado/2017.3/data/ip/xilinx/xdma_v4_0/hdl/xdma_v4_0_vl_rfs.sv(64): (vlog-2583) [SVCHK] - Some checking for conflicts with always_comb and always_latch variables not yet supported. Run vopt to provide additional design-level checks.
** Warning: C:/Xilinx/Vivado/2017.3/data/ip/xilinx/xdma_v4_0/hdl/xdma_v4_0_vl_rfs.sv(64): (vlog-2600) <protected>
-- Compiling package xdma_v4_0_vl_rfs_sv_unit
** Error: (vlog-13069) C:\Users\sab\AppData\Roaming\Xilinx\Vivado\.cxl.ip/incl/xdma_axi4mm_axi_bridge.vh(204): syntax error, unexpected "SystemVerilog keyword 'endpackage'", expecting class.
-- Compiling interface dma_pcie_axis_cc_if
-- Compiling interface dma_pcie_axis_cq_if
-- Compiling interface dma_pcie_axis_rc_if
-- Compiling interface dma_pcie_axis_rq_if
-- Compiling interface dma_pcie_c2h_crdt_if
-- Compiling interface dma_pcie_dsc_in_if
** Error: C:\Users\sab\AppData\Roaming\Xilinx\Vivado\.cxl.ip/incl/dma_pcie_dsc_in_if.svh(6): 'dma_dsc_in_crd_t' is an unknown type.
Or did you omit the '()' for an instantiation?
** Error: C:\Users\sab\AppData\Roaming\Xilinx\Vivado\.cxl.ip/incl/dma_pcie_dsc_in_if.svh(7): 'dma_dsc_block_t' is an unknown type.
-- Compiling interface dma_pcie_dsc_out_if
** Error: C:\Users\sab\AppData\Roaming\Xilinx\Vivado\.cxl.ip/incl/dma_pcie_dsc_out_if.svh(6): 'dma_dsc_out_crd_t' is an unknown type.
** Error: C:\Users\sab\AppData\Roaming\Xilinx\Vivado\.cxl.ip/incl/dma_pcie_dsc_out_if.svh(7): 'dma_dsc_block_t' is an unknown type.
-- Compiling interface dma_pcie_fabric_input_if
-- Compiling interface dma_pcie_fabric_output_if
-- Compiling interface dma_pcie_gic_if
-- Compiling interface dma_pcie_h2c_crdt_if
-- Compiling interface dma_pcie_mi_16Bx2048_4Bwe_ram_if
-- Compiling interface dma_pcie_mi_2Bx2048_ram_if
-- Compiling interface dma_pcie_mi_4Bx2048_4Bwe_ram_if
-- Compiling interface dma_pcie_mi_64Bx128_32Bwe_ram_if
-- Compiling interface dma_pcie_mi_64Bx256_32Bwe_ram_if
-- Compiling interface dma_pcie_mi_64Bx512_32Bwe_ram_if
-- Compiling interface dma_pcie_mi_8Bx2048_4Bwe_ram_if
-- Compiling interface dma_pcie_mi_dsc_cpld_if
-- Compiling interface dma_pcie_mi_dsc_cpli_if
-- Compiling interface dma_pcie_misc_input_if
-- Compiling interface dma_pcie_misc_output_if
** Error: (vlog-13069) C:\Users\sab\AppData\Roaming\Xilinx\Vivado\.cxl.ip/incl/dma_pcie_misc_output_if.svh(157): syntax error in protected region.
-- Compiling module xdma_v4_0_0_BufferMem
-- Compiling module xdma_v4_0_0_GenericFIFO1R2W
-- Compiling module xdma_v4_0_0_GenericFIFOAsyncNoHead
-- Compiling module xdma_v4_0_0_GenericFIFOHead
-- Compiling module xdma_v4_0_0_GenericFIFOHead2
** Error: (vlog-13069) C:\Users\sab\AppData\Roaming\Xilinx\Vivado\.cxl.ip/incl/axidma_fifo.vh(1123): syntax error in protected region.
** Warning: C:\Users\sab\AppData\Roaming\Xilinx\Vivado\.cxl.ip/incl/axidma_fifo.vh(1123): (vlog-2583) [SVCHK] - Some checking for conflicts with always_comb and always_latch variables not yet supported. Run vopt to provide additional design-level checks.
** Warning: C:\Users\sab\AppData\Roaming\Xilinx\Vivado\.cxl.ip/incl/axidma_fifo.vh(1123): (vlog-2600) <protected>
End time: 18:26:10 on May 09,2020, Elapsed time: 0:00:04
Errors: 54, Warnings: 62
Library 'ldpc_v1_0_0' compilation error(s)
Start time: 18:35:43 on May 09,2020
vlog -32 -L fec_5g_common_v1_0_0 -L ldpc_v1_0_0 "+incdir+C:\Users\sab\AppData\Roaming\Xilinx\Vivado\.cxl.ip/incl" -sv -work ldpc_v1_0_0 -f C:\compiled/ldpc_v1_0_0/.cxl.systemverilog.ldpc_v1_0_0.ldpc_v1_0_0.nt64.cmf
** Error: (vlog-13069) C:/Xilinx/Vivado/2017.3/data/ip/xilinx/ldpc_v1_0/hdl/ldpc_v1_0_rfs.sv(64): syntax error in protected region.
End time: 18:35:45 on May 09,2020, Elapsed time: 0:00:02
Errors: 2, Warnings: 1
 Thank you in advance
philipwu
Hi @fsabbari,
ModelSim 10.7 is not supported on earlier versions of Vivado (2017.3) Please refer to the attached link to see which Vivado versions support which Third party simulators.
ModelSim 10.7 is supported on Vivado 2019.1 and up.
https://www.xilinx.com/support/answers/68324.html
