Participant gmoore
Error Simulating with Cadence Simvision
This post is caused by the same issues outlined in the thread linked below :
https://forums.xilinx.com/t5/Simulation-and-Verification/mipi-dphy-rx-tx-simulation-with-Cadence-Simvision/m-p/802489#M19797
Within that thread, it was suggested to me that if I followed the steps outlined in this thread, the issue would be solved:
https://forums.xilinx.com/t5/Simulation-and-Verification/compile-simlib-error-again-after-INCISIV-version-fix/td-p/539099
However, that is not the case. The error persists, even after performing the additional necessary correction of editing the filepaths, as suggested by kynthia9:
https://forums.xilinx.com/t5/Simulation-and-Verification/compile-simlib-error-again-after-INCISIV-version-fix/m-p/540383/highlight/true#M11397
After I edit the .cmd files I get the following errors:
.cxl.vhdl.unisim.unisim.lin64.cmd
ncvhdl(64): 15.10-s014: (c) Copyright 1995-2016 Cadence Design Systems, Inc.
/cad/adi/apps/xilinx/vivado/2017.1/Vivado/2017.1/data/vhdl/src/unisims/unisim_retarget_VCOMP.vhdp:
ncvhdl_p: *F,DLUNNE: Can't find STANDARD at /cad/adi/apps/cadence/incisive/linux/15.20-s30/tools.lnx86/inca/files/STD.
/cad/adi/apps/xilinx/vivado/2017.1/Vivado/2017.1/data/vhdl/src/unimacro/unimacro_VCOMP.vhd:
/cad/adi/apps/xilinx/vivado/2017.1/Vivado/2017.1/data/vhdl/src/unifast/primitive/DSP48E1.vhd:
Re: Error Simulating with Cadence Simvision
Hi @gmoore,
Are you seeing this issue with Incisive Enterprise 15.20.014 ?
prathikm
Participant gmoore
The version of IES I am using is 15.20-s30
Hi @gmoore
Do you have a vivado based project? If yes, can you try running export_simulaion command in the tcl console.
This will create the sample scripts required to run the design in IES. You may use them to compare against your custom scripts and do the necessary modifications,
Thanks,Vijay
