Error in compile_simlib for Questa Sim 10.6c
I am getting a compile simulation library error for  processing_system7_vip_v1_0_5 and zynq_ultra_ps_e_vip_v1_0_3. I am using vivado 2018.2 and Questa sim 10.6c.
How to solve the error?
Attached u will find the log file.
Suhas
Re: Error in compile_simlib for Questa Sim 10.6c
Hi @suhas_shivaprakash,
Can you please attach the log file again. I do not find the log file attached here.
Thanks & Regards,
Sravanthi B
Here it is,
I have attached both the log file and error log file.
Suhas.S
I see the following warning in the log file.
WARNING: [Vivado 12-5495] Detected incompatible questasim simulator installation version '2017'! The supported simulator version for the current Vivado release is '10.6c'.
The compatible version with Vivado 2018.2 is 10.6c.
As I had mentioned before, I am using the Questa sim 10.6c in the simulator executable path, also I am using vivado 2018.2 version. So how can this problem occur??
Attached u can find the snapshot of the compile simulation library window.
Suhas.S
You're using 10.6c-1, which looks to be an overlay on top of 10.6c.
We recommend that you use 10.6c as this is the version that has been tested.
As you said I downgraded questasim from 10.6C-1 to 10.6C. But still the same problem exists.
Attached you can see in the vivado.log file, that correct questa sim version has been taken
Suhas.S
What is the specific Questa product configuration? Questa Core or Questa Prime?
Some of our product such as AXI VIP uses special SV verification constructs (constraint randomization) – that are supported on Questa Prime only – we test it on Prime only. But other standard simulation flow items are supported on both core/prime.
I am using questa sim advanced simulator 10.6c supported with core and prime version. The adaptability is in accordance with the vivado version reported here.
https://www.xilinx.com/support/answers/68324.html
Suhas.S
Can you please share the compile_simlib.log and the cxl_error.log files generated while using Questasim 10.6c.
Thanks & Regards,
Sravanthi B
Hello @bandi,
It is attached here.
Suhas.S
Hello @bandi,
The compile_sim_lib.log is attached here.
Suhas.S
