Error in simulation
hi guys!
I am using ISE v10.1 to implement the FPGA designs.
I write a simple small program in VHDL to implement 'ADD' operation, the folowing:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity ADDER is
    port(
            a : in signed(3 downto 0);
            b : in signed(3 downto 0);
            c : out signed(4 downto 0) );
end ADDER;
architecture Behavioral of ADDER is
begin
    c <= a+b;
end Behavioral;
But i can't simulate it. when I simulate ISE generate the errors:
please help me to explain that error (why? and how correct it?). Thank you very much!
all my project attach below.
I'm Hung
besides the fact that you should use numeric_std package instead of  STD_LOGIC_ARITH and STD_LOGIC_UNSIGNED this seems to be a problem of your machine or installation. The tool just crashed, and that can have lots of causes.
Also you mentioned to be using ISE 10.x. What simulator are you using? ISIM? That was very fresh and buggy at that time.
Maybe you should consider to use an actual version of ISE/ISIM.
Have a nice simulation
  Eilert
thank you eiler!
I use ISE simulator.
can everyone explain clearly to me for it?
I'm Hung
Hi Hung,
I agree with eiler. 10.x is really an older version of tool. I ran your design in 13.1 ISE Simulator and it ran fine but I couldn't find any testbench for your module in it. Have you written one? If not try creating a testbench and provide stimulus for a and b and run it in ISIM. The code looks fine.
Debraj
Thank debrajr!
I really wrote testbench and do it again several time.
I will retry with respect to you.
I'm Hung
This issue was resolved in service pack 2 of 10.1. Here is an answer record describing a similar issue.:
http://www.xilinx.com/support/answers/31079.htm
Hope this helps ...
