mani_905
Error of Behavioral Simulation
I am not getting simulation  of a VHDL program  but Its RTL schematic can be generated.It is showing error in XST simulator.Please anyone  tell me the solution as soon as possible.
bandi
Hi @mani_905 ,
Can you please share the error message which you have come across while simulating in ISIM? Are you using ISE 14.7 and on which OS?
Thanks & Regards,
Sravanthi B
mani_905
OS is windows 10 and i am using xilinx 9.2i
shameera
HI @mani_905 ,
You can try to simulate individual files present in the hierarchy to find which file contains the code due to which ISE is giving the error.
As its a very older version tool, you can also give a try migrating to ISE 14.7 or latest VIvado version (2018.3).
