Error opening trace files in vivado 2014.3
Hi all
I am following the ug871 on vivado_hls + vivado
I'm currently stuck trying to open a trace file with vivado (TRL verification chapter)
When I try to open the file, I get an error:
[Vivado 12-106] *** Exception: java.lang.reflect.InvocationTargetException (See /scratch/nas/1/antoniof/hardware/Vivado_HLS_Tutorial_2014.3/RTL_Verification/lab2/duc_prj/solution1/sim/verilog/vivado_pid725.debug)
I've attached this error file, the stack trace that shows the error message and the log file.
I'm running vivado (2014.3) on a ubuntu 14.04 machine.
This seems to be related with another problem I had.
It seems that there is a missing java file that affects the trace visualization.
See
http://forums.xilinx.com/t5/Simulation-and-Verification/Java-exceptions-running-simulation-in-vivado-2014-3/td-p/552697
See
