simon.stephany
Error trying to run simulation with IP AXI_BRAM_CTRL
I try tu simulate a design where a axi vip is connected to a axi_bram_ctrl that is connected to a custom bram and I get this error. I have hardly any warnings and it synthesises just fine, and the post synthesis simulation works ERROR: [VRFC 10-149] 'axi_bram_ctrl' is not compiled in library axi_bram_ctrl_v4_0_14
graces
Are you running with Vivado Simulator or 3rd party simulators?
For the latter, make sure you have successfully pre-compiled simulaiton libraries and load all necessary libraries (including IP libs) in simulation. You can try to launch simulation from within Vivado GUI and take a look at the auto-generated simulation scripts for reference.
simon.stephany
I'm running Vivado Simulator, I'm running everything from Vivado GUI. Pre-compiling the simulation librarys is for 3rd party simulators from my understanding?
