11-06-2017 04:11 PM
module CounterMux(clk, reset, sel, LED);
// Inputs
input clk, reset;
input [1:0] sel;
//output
output reg [7:0] LED;
reg [31:0]out1;
reg [31:0]Q;
reg [7:0] d1,d2,d3,d4;
Bit32 counter_inst(clk, reset, out1, Q);
d1 <= Q[7:0];
d2 <= out1[15:8];
d3 <= out1[23:16];
d4 <= out1[31:24];
always @*
begin
case(sel)
2'b00 : LED <= out1[7:0];
2'b01 : LED <= out1[15:8];
2'b10 : LED <= out1[23:16];
2'b11 : LED <= out1[31:24];
default : LED <=0;
endcase
end
endmodule
ERROR CODE: Line 16: Target <out1> of concurrent assignment or output port connection should be a net type.
11-06-2017 08:13 PM
Hello @cotton117,
I think you are trying to implement some special kind of counter example here.
Please try to write complete sensitivity list and use If-Else looping rather than case statement.
The '*' can be used as short of all inputs only if logic inside always block is purely combinational.
Hope this resolves your query.
Thank you.
11-08-2017 08:32 PM
Your coding/style needs a lot of work, too, but this is your immediate problem:
-Joe G.
