jujubill
Errors with compile_simlib including ise_install_path
Dear All,
I try to compile a sim lib with all families and legacy ones because I need KintexUS and Virtex6.
I'm using Vivado 2016.4 and QuestaSim 10.5c (the compatible one).
ISE is 14.7 (needed I think to include legacy families).
I lauch this command in vivado (inspired from AR# 64056):
"compile_simlib -ise_install_path C:/Xilinx/14.7/ISE_DS/ISE -simulator questa -simulator_exec_path C:/questasim64_10.5c/win64"
The libraries are compiled in C:/Users/me/AppData/Roaming/Xilinx/Vivado
This dir is now 4.16GB (including a .Xil directory I'd like to know more about because it is absent when I specify another destination path).
The result is not error free:
"ERROR: [Vivado 12-3591] compile_simlib failed to compile for questasim with 4 errors."
4 library compilations finished with errors : xpm, v_st2059, cpri_v8_7_1, mdm_v3_2_8.
When I open compile_simlib.log, I have these error messages (see compile_simlib.log_extract.txt) :
Could you help me on this please?
Martin
