External SRAM implementation and Test bench
Hi All,
In our project we are using Sparton 6 FPGA with  external 128K X 8 bit CMOS SRAM.
I am new to VHDL coding, i don't know how to write Test bench to this implementation
please share if any related links and code to referer
Could anyone give me suggestions?
Thanks a lot!
Re: External SRAM implementation and Test bench
Many commercial RAMs have simulation models available.  Have you searched the manufacturer's for a simulation model?
No,We are using Par# LP62S1024BV-70LLIF 128K X 8
SRAMs are fairly simple. It shouldnt be hard to create your own model using the datasheet.
Can you please provide some sample codes or links
siva
Hi Sive,
You can probably google around and find some direct examples. Here's one such example for a SRAM and testbench in VHDL.
https://www.fpga4student.com/2017/08/vhdl-code-for-single-port-ram.html
You can also pull SRAM that is similar to the one you have to model. Ensure that it's similar in the bus interface and you should be (mostly) good.
For instance, Cypress provides models:  Here's several models:
https://www.cypress.com/search/all?f[0]=meta_type%3Asoftware_tools&f[1]=field_related_products%3A1275&f[2]=software_tools_meta_type%3A580
Have fun,
Jerry
