Observer trungnguyen
[FATAL_ERROR] Vivado Simulator (2018.3)
Dear all,
I get the following error when running ISIM simulation:
FATAL_ERROR: Vivado Simulator kernel has discovered an exceptional condition from which it cannot recover. Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support.
Time: 0 ps  Iteration: 0  Process: /tb_pusch_bp/line__142
The line of code causes the error:
db_rm_null_tdata       <=  << signal .tb_pusch_bp.UUT.pusch_bit_proc_i.remove_null_0.dout_tdata: STD_LOGIC_VECTOR(127 downto 0)>>;
My context is:
- I want to get the value of dout_tdata of a sub-component and write that value to file.
- I've already set VHDL-2008
Could you give me a hand to overcome this issue?
Trung Nguyen
Scholar drjohnsmith
Re: [FATAL_ERROR] Vivado Simulator (2018.3)
This should be your first port of call
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug901-vivado-synthesis.pdf
Xilinx are primarily Verilog and HLS . Unfortunately for anywhere else apart from the west coast of the US, VHDL is very badly supported.
table 5-10 is a good start
and chapter 6 shows the limited 2008 support
I cant see hierarchical names supported
Scholar drjohnsmith
Thank you.
I resolved this problem by calling the equivalent signal which is outside subcomponent.
Best Regards,
Trung Nguyen
