FATAL_ERROR
Hi iam getting the following error in Xilinx ISE Suite 14.2 . Please help me on this.What could be the wrong with my project..
FATAL_ERROR:Simulator:CompilerAssert.h:40:1.67 - Internal Compiler Error in file ../src/VhdlExpr.cpp at line 587 Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support.
Hi @raji55544 ,
I tried checking this code at my end and i see that the fatal error occurs due to the below assignment of x1,x2,x3 of module instantiation dadda_multi, as while tried commenting these i was able to run through simulation without any issues.
Hence, please try portmapping the instantiation module properly in the top module.
Thanks & Regards,
Sravanthi B
