Newbie amikha16
FATAL error
When Iam simulating my project then an error is coming every time.
This error is as:-
"FATAL_ERROR:Simulator:CompilerAssert.h:40:1.41 - Internal Compiler Error in file ../src/VlogSeqStmt.cpp at line 4730 Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support."
And this error is written two times on each simulation...
Re: FATAL error
Which version of ISE are you using?
Is this error seen with all designs or a specific design?
Can you attach the test case so that we can check the reason for failure?
Deepika.
Deepika.
Newbie amikha16
Re: FATAL error
Hello...
Thanks for reply.
I am using Xilinx ISE 13.4
This error is coming with particular design, not with all. Sorry, I can't attach my case due to some reasons.
Amit Khandelwal
Scholar pratham
Re: FATAL error
Can you give a try by upgrading ISE?
If you can not share your design files here let me know, i can send you official link to upload your project there?
-Pratham
Newbie amikha16
Re: FATAL error
Plz give me official link.
There is 1 more error with all designs that
"Your software subscription period has lapsed. Your current
version of Xilinx tools will continue to function, but you no longer qualify for
Xilinx software updates or new releases"
Should I update it or reinstall it ?
Amit Khandelwal
Re: FATAL error
See this answer record: http://www.xilinx.com/support/answers/34097.html
It explains the reason for the message "Your software subscription period has lapsed. Your current version of Xilinx tools will continue to function, but you no longer qualify for Xilinx software updates or new releases"
Re: FATAL error
The fatal error is most likely a tool bug. If no newer ISIM version can be tried out, you need to narrow down the issue to specific file/module and try to find out a workaround.
What's the last module compiled before the error occurs?
You may also enable "-v 1 -mt off" switch in Other Compiler Options to see if more details are printed.
If you can provide the test case, I'll take a look at it and hopefully find out a solution.
Re: FATAL error
Which OS are you using?
Debraj
