alfamanager
FIFO Generator AXI Stream Interface Simulation Problem
Hello guys!
I want to see simple simulation of FIFO Generator 13.2 with AXI-Stream.
When I use this IP-Core, my simulation is not resulting properly.
How could I simulate this IP-Core without connect anywhere.
You can see the codes also.
dpaul24
@alfamanager ,
You see the tvalid and tready signals? They should not be Xs. It should be driven.
Also I see that in your testbench, the axis signals are first driven and then you are driving resetn to high. Design should be brough out of reset first and then the AXIS signals should be driven.
btw - I told you in a similar post yesterday to look at the example_design testbench in the FIFO Generator AXI Stream Xilinx docu. Did you study it?
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
alfamanager
 I saw the example design but I need vhdl testbench I couldn't understand that. I need simple one IP-Core sim.
