Find the errors in the Verilog Code
Hello guys, below is a peice of verilog code, there are 5 errors in the code, please highlight/underline the errors and correct them. (please make sure to underline/highlight the errors/changes you have made. Thank you.
module multiplier (clk, M, A, B, P)
   input clk, M;
   input [7:0] A;
   input [3:0] B;
   output [11:0] P;
   wire [8:0] temp;
   reg [11:0] P;
   adder  (temp, P[11:4], A);
   always @(posedge clk)
       if(!M)
           P <= {8'b0, B};
   always @(posedge clk);
      begin
         if(M)
           if (P[0])
              P <= {temp, P[3:0]} >> 1;
          else
           P <= P >> 1;
   end
endmodule
module adder ( X, Y);
   input [7:0] X, Y;
   output [8:0] Cout_Sum;
     assign Cout_Sum = X + Y;
endmodule
Re: Find the errors in the Verilog Code
We are not here to correct your codes. you should be able to do it by your self.
module multiplier (clk, M, A, B, P);
Rest errors you should find by your self.
-Pratham
May I know the intention of this post? Forums are for those who has issues and need help to solve them, not for puzzles.
Thanks,Vijay
I feel you should read verilog books for proper syntax and coding styles.
Try to find out the mistakes you have done..there are no of mistakes which simply i cant point out here. May be you can take a look at the modifed code and see what went wrong.
-Pratham
Easiest way is to run Check Syntax in ISE and fix the error for yourself :) We at Forums are here to help and not solve puzzles.
Debraj
Well it's actually an assignment not a random puzzle, and we literally just started the class. So I have no clue as to what's going on here.
The way you said was totally incorrect. No one is here to correct your assignment.
would be better  if you think before post!!!
-Pratham
Sorry didn't mean to upset you guys, this is my first time posting here. Really sorry.
Historian
Historian
I've contacted your professor and informed him that you're asking others on a public forum to do your homework for you.
Expect a failing grade this semester.
are you really trying to get us to do your homework?
Hello muz and bass man. It may seem so but I just want to know what the errors are personally. I've already done it, I just need reassurance.
if that's the case, post your answers and ask if they are correct. earlier you said: "So I have no clue as to what's going on here." so you might be able to use the commentary.
I have written all the errors I could find in RED, apologies again, I noticed I clearly upset a lot of people and I am truly sorry for the misunderstanding.
module multiplier (clk, M, A, B, P); There isn't a semicolon here
   input clk, M;
   input [7:0] A;
   input [3:0] B;
   output [11:0] P;
   wire [8:0] temp;
   reg [11:0] P;
   adder  (temp, P[11:4], A); Adder doesn't have a name
       Begin
        if(!M)
       End
           P <= {8'b0, B};
   always @(posedge clk); There shouldn't be a semi-colon here
      begin
         if(M)
           if (P[0])
          else
           P <= P >> 1;
   end
endmodule
module adder ( X, Y); Cout_Sum isn't declared here
   input [7:0] X, Y;
endmodule
Thats good! If using Project Navigator Check Syntax would come handy as we all at some point of time have committed Syntax errors :) Happy Posting!!
Debraj
Historian
Historian
isn't that why you pay your instructors? You should be able to go to the teaching assistant or the class instructor and have it explained to you.
this is my initial look there are still errors
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date: 16:36:46 04/18/2014
// Design Name:
// Module Name: Multiplier
// Project Name:
// Target Devices:
// Tool versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module multiplier (input clk, M, A, B, output P);
//input clk, M;
//input [7:0] A;
//input [3:0] B;
//output [11:0] P;
wire [8:0] temp;
reg [11:0] P;
if(!M)
P <= {8'b0, B};
begin
if(M == 1)
if (P[0] == 1)
P <= {temp, P[3:0]}; //>> 1;
else
P <= P ;//>> 1;
end
endmodule
input [7:0] X, Y;
endmodule
@mnfsoft Can you post a new topic & also mention the error you are seeing.
Thanks,Vijay
