Flip-Flop D abnormal behaviour
Hi everyone,
I can't understand why some simple flip-flops are acting different from their normal behaviour. They don't respect the clock edges and the first of the two is even sampling different values from those is taking in input. Below there are the code of the FFs and the behavioural simulation.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity reg8bitf is
port ( D_r8 : in std_logic_vector(7 downto 0);
       CE_r8 : in std_logic;
       CLKD_r8: in std_logic;
       Q_r8 : out std_logic_vector(7 downto 0):=(others=>'0'));
end reg8bitf;
architecture Behavioral of reg8bitf is
begin
process(CLKD_r8)
begin
if (rising_edge(CLKD_r8) ) then
if (CE_r8='1') then
Q_r8 <= D_r8;
end if;
end if;
end process;
end Behavioral;
Hello CV330,
I recommend opening a new thread on the timing closure type questions.  This will insure the correct experts will address your concerns.
Chris
You have only posted one peice of code. Where is the testbench that is generating the waveform? and why are there 2 sets of signals? you also didnt include CE on the waveform.
Please rephrase the question to something more coherent.
Hi @cv330
Based on your code i have tried behav. simulation. I did not find any issues. please have a look.
If you have a testbench on which you are facing issues, please provide.
hemangd
hemangd
Excuse me for the lack of data in my question. At the end i've got around the problem changing the structure of the circuit.
Now I have another question which however isn't related with this post, is about timing closure and high percentage of net delay with only 2 logic levels on the path. Can I show what i've got here or I have to open another thread?
Hello CV330,
Chris
