Visitor dr_graham7
Functional Simulation wrong latency reading UltraRAM
Hello All,
I am having a problem understanding why the first read from an UltraRAM in a behavioural Simulation (using Modlesim DE and a VHDL design) is taking 4 clocks when it should be 1 ? Has anybody else seen / solve this issue please ?
Basically i have instantiated 3 UltraRAMs a s a row to provide x3 x72 = 216 bit words. My UltraRAM cores all have
IREG_PRE_A, IREG_PRE_B and OREG_A and OREG_B set as FALSE. So i was expecting to see the data D0 pop out of the read port the cycle after the port a address appears. (ENA_A = 1 and RDB_WR_A = 0).
That is not the case...as i increment address on read port a i see the data at output port a stay at the same value for  address 0 for 4 clocks...then it changes correctly after each address increment and the port a output data changes on every clock cycle. But what is happening on the first memory read access ..why the 4 clock latency ?
thanks for your help,
Dr Barry H
Re: Functional Simulation wrong latency reading UltraRAM
Hi @dr_graham7,
Have you allowed for the GSR (global set reset) to clear?
This takes 100ns and is taken into account when you run a functional simulation and not the behavioural simulation.
The reason for this is that the functional simulation simulates real hardware, while the behavioral simulation simulates the HDL.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
Visitor dr_graham7
Hi Aidan,
thanks for your reply. Yes i know about the GSR .... i have been caught out before with that one ! This time it was due to me not quite getting the right signals on my simulation ...i wasnt looking at the address at the lowest level of the core. When i did that things looked correct ! Thanks for your help anyway.
cheers, Dr Barryh
