aripod
Generic parameter not changing in simulation
I have some generic parameters defined in my entity
entity WIZ820_interface is
    generic(
            DIV_1 : integer := 250;
            DIV_2 : integer := 125;--<-DEBUGING125000;
            CLK_SPI : integer := 125
    Port ( clk : in STD_LOGIC;
The first time I ran the simulation, DIV_2 was 125000. Then, I changed the .vhd file to 125 like shown in the snipper, but when I reset the simulation, DIV_2 is still 125000 and not 125 as I want. Is there something to change, besides in the .vhd code?
Thanks for the help.
amaccre
Hi @aripod ,
If the above suggestions do not work for you, try deleting the .sim directory from your project.
It will be recreated automatically when you run simulation again.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
shameera
Hi @aripod ,
Can you once try by disabling incremental Compilation from Vivado Settings --> SImulation -->Advance --> uncheck "Enable Incremental Compilation" and see if it helps ?
dpaul24
@aripod,
Also try out Vivado Settings --> SImulation --> Reset Behavioral Simulation
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
amaccre
Hi @aripod ,
Best Regards
Aidan
ronnywebers
Advisor
Advisor
This is a kind of old, annoying bug in Vivado, where a change in a constant or generic does not retrigger a regeneration of the simulation files.
Indeed as @amaccre suggest, you'll can first try to 'end' the simulation, and then relaunch it.
If that didn't work, (I know for sure that in Vivado 2017.2 this often was not sufficient), you'll needed to manually delete the simulation files (delete the entire .sim folder), so Vivado is forced to generate them again.
I recently tried the same in 2018.2 and there it seems to be fixed, though I should double-check that again.
What version are you working with?
