Get the real clock time in simulation - get_clocktime
Is there a way to get the real time clock in a VHDL test bench in Vivado?
In ModelSIM I'm using the modelsim_lib library that comes with get_clocktime, which allows for things like:
signal mti_sim : mti_clocktime_rec := get_clocktime(-1, TRUE);
constant file_name : string := "sim_log_" & integer'image(mti_sim.year) & "-" & integer'image(mti_sim.month) & "-" &
                               integer'image(mti_sim.day) & "_" & integer'image(mti_sim.hour) & "h" &
                               integer'image(mti_sim.minute) & "m" & integer'image(mti_sim.second) & "s.log";
/F
Re: Get the real clock time in simulation - get_clocktime
VHDL has no standard way of getting the system time.
Modelsim have provided a library that allows this (probably via system hooks) but this is proprietary to modelsim. Other vendors may also provide their own libraries for this (I doubt Xilinx does) but it will be not be compatible with other tools.
VHDL 2019 does provide a standardised mechanism for this, but 3rd party tools from Aldec and Mentor are only just starting to support this standard. Xilinx still provides little simulation support for VHDL 2008, so dont expected VHDL 2019 support anytime soon.
Anyone? How do I get the wall clock time in the Vivado simulator?
Or am I forced to use SystemVerilog and try to get that into the VHDL test bench?
void'($system("date +%X--%x > sys_time"));
/F
EDIT: Seems like $system isn't supported.
Thanks for answering. Yes, I was thinking about a Xilinx provided library similar to the modelsim_lib.
And I've been painfully aware of the poor VHDL 2008 support in Vivado...
After digging deeper, the only way to get the wall clock time seems to be a TCL script (https://stackoverflow.com/questions/18141851/compile-date-and-time-in-fpga). Then using the xsim.compile.tcl.pre setting in Vivado to run the TCL script before launching the simulation. Or to use a completely scripted simulation.
/F
