Visitor fadia
Help in simulating ALU
I need to design register file that is connected to an ALU in systemverilog,
then simulate the top module to verify that operations are performed correctly.
I attached three modules, alu, register file, top module.
I have verified that the alu itself works by running simulation independently from the register file.
Yet, when I run simulation for the top module I get dont care for the first bit of the result.
So the result gets loaded in the register file via WD (write data port) when EN is high.
Then what is A3.
Can someone explain more about register file.
Re: Help in simulating ALU
Hi @fadia,
I must say that I don't understand your question. Could you give more detail about what you are looking for?
What do you mean by " what to use for the output of the topalu module". Do you mean the data type?
Florent
Visitor fadia
Thanks for your reply, I rewrote my question.
Hi @fadia,
Please do not change your initial question, else the following replies can make no sense. If you need to add more information, reply to the topic.
I still do not understand what you are looking for...
You designed a register file but you are asking about it...
Florent
Visitor fadia
I am having trouble in getting the result out when I do simulation. I input two numbers but I get don't care for the output.
Hi @fadia,
I guess this is because you are not initializing your memory before reading it. So the simulator tells you the value outputted can be any value
Florent
Visitor fadia
I tried to do simulation for the register file alone. It works only when I have A1 A2 A3 = to same number, the output will follow whatever is in WD.
Can you help understand what I am doing wrong.
Hi @fadia,
If A1 A2 A3 = to same number, then you are initializing the memory (with A3) and reading back this value (with A2 and A1)
Florent
