Help me,please!I use the IBUFGDS in Virtex-5,but Modelsim can not simulation.
Hi!
I use the IBUFGDS in my design(virtex-5,IXE10.1.03,ModelsimSE6.2b), but simulation can not success.
Thank you very much!!!
The waring is :
** Warning: (vsim-3473) Component instance "uut : ibufg" is not bound.
#    Time: 0 ps  Iteration: 0  Region: /tb1/uut  File: module_IBFGDS.vhd
Re: Help me,please!I use the IBUFGDS in Virtex-5,but Modelsim can not simulation.
Bassman refers to the following lines in your VHDL sources:
Library UNISIM;
use UNISIM.vcomponents.all;
Have you included this library declaration in all source code that instantiate Xilinx UNISIM primitives (ibufg, DCM, etc.)?
Eddie
Historian
Historian
Did you include the library use clause for the unisim vcomponents library?
-a
Yes, I had comiled all the library and varied the modelsim.ini.
Library UNISIM;
Eddie
