How can I run a post-synthesis simulation model?
I'd like to run a generated post-synthesis simulation model, which should be a simple task. But so far, I cannot work out how to do it.
So far, in ISE, I've run the synthesize step, and then the "Generate Post-Synthesis Simulation Model". This creates the file "./netgen/synthesis/top_level_synthesis.vhd". Thats fine. But what do I do with it?
The file does not show up anywhere in the design hierarchy view for simulation (or implementation), and also does not show up at all in the Files view. If I try to import it by right-clicking and selecting "Add Source", i'm told the file is already included in the project, even though it does not appear in the files tab.
I've been assuming that the file would appear under the simulation hierarchy view, where I could just wrap a testbench around it, and run ISIM. No such luck.
Can anyone enlighten me on the procedure?
Thanks very much,
Rob Smith
Professor
Professor
In the simulation view there should be a drop-down bar that is probably currently showing
"Behavioral".  Click on the down arrow to the right and select "post-translate" to change to
the post-synthesis simulation.
HTH,
Gabor
-- Gabor
Professor
Professor
HTH,
Gabor
-- Gabor
In all my searching, i'd completely missed that drop-down box!
Thank you very much Gabor.
I had exactly the same problem. I had also missed the dropdown bar. Thanks for solution. I think Xilinx people should highlight this in their literature.
