hyleung
How to change Bus Interface property FREQ_HZ value of System ILA
The default value of the FREQ_HZ is 100MHz.  How can I change it to another value?
hyleung
Thanks florentw.  Problem fixed.
florentw
HI @hyleung
You need to cahnge the frequency of the clock of the ILA and click validate block design to propagate the parameter
Florent
hyleung
