How to create test bench for system_stub.vhd
hello,
  What's the best way to create a test bench for system_stub.vhd that contrain system component, its
Instantiation and bunch of other blocks, etc?  End up renaming system_stub.vhd to system_stub_tb.vhd and removed system component and its instantion and created the system's clk and reset inside the system_stub_tb.vhd. Is there a better way to do this? Is there any example out?
Best regards,
Fred
Re: How to create test bench for system_stub.vhd
Fred,
Refer to the discussion in the thread which may give you some insight.
http://forums.xilinx.com/t5/Design-Entry/Vivado-How-to-create-automatic-testbench-files/td-p/266396
Few IP in the Vivado IP catalog generate testbench for testing.
Achutha
Hi I reviewed it but didn't find it much useful beside creating a empty testbench LOL Is there any tutorial or apps note on how to simulate a zynq emmbeded design?
Regards, Fred
hello @achutha,
  You never get back to me regarding the questions I asked about writing a testbench for an embeded system? Any help?
Fred
Have your checked the XAPP: http://www.xilinx.com/support/documentation/application_notes/xapp744-HIL-Zynq-7000.pdf ?
Debraj
