Visitor yahoogary
How to deal with missing "libxil_vsim.dll" when run simulation under the XPS?
# vsim +notimingchecks -L xilinxcorelib_ver -L secureip -L unisims_ver -pli libxil_vsim.dll -t ps -novopt bfm_system_tb glbl
# Loading libxil_vsim.dll
# ** Error: (vsim-3193) Load of "libxil_vsim.dll" failed: File not found.
# ** Error: (vsim-PLI-3002) Failed to load PLI object file "libxil_vsim.dll".
#         Region: /
# Loading work.bfm_system_tb
# Loading work.bfm_processor_wrapper
# Loading cdn_axi4_master_bfm_wrap_v2_01_a.cdn_axi4_master_bfm_wrap
# Loading work.axi4_bus_wrapper
# Loading axi_interconnect_v1_04_a.axi_interconnect
# Loading axi_interconnect_v1_04_a.ict104_register_slice_bank
# Loading axi_interconnect_v1_04_a.ict104_protocol_conv_bank
# Loading axi_interconnect_v1_04_a.ict104_converter_bank
# Loading axi_interconnect_v1_04_a.ict104_data_fifo_bank
# Loading work.glbl
# Error loading design
Re: How to deal with missing "libxil_vsim.dll" when run simulation under the XPS?
Make sure XILINX env variable is set correctly.
For example, XILINX = C:\Xilinx\13.4\ISE_DS\ISE
Visitor yahoogary
I have set two system variables:
XILINX= C:\Xilinx\13.4\ISE_DS\ISE
XILINX_EDK= C:\Xilinx\13.4\ISE_DS\EDK\bin\nt64
But still has same same error message.
Is it because I also need setting something inside of modelsim.ini?
-----------------error message-----------------------------
# ** Error: (vsim-3193) Load of "libxil_vsim.dll" failed: Bad DLL format.
#         Region: /
# Loading work.glbl
# 1
Does the "libxil_vsim.dll" exist in current directory?
Make sure the dll is not corrupt as the error indicates bad format.
OR, you can try pointing to the same dll file at $XILINX/lib/nt
Visitor yahoogary
thanks for your help, graces.
yes, I have copied " libxil_vsim.dll" to local project.
what is " libxil_vsim.dll"? is it related AXI BFM?
According to DS824, the dll is VPI library file that enables licensing.
Visitor yahoogary
Can anyone run DS824 example successfully? Thanks
Newbie zaaylo
after copy of dll file (libxil_vsim.dll  ) to my local pc. its seems better is it need to replace this dll file or any requirnment to replace the dll ?
Visitor arel
Does anybody solve this problem? It seems like "libxil_vsim.dll" is 32-bit and problem exist on 64-bit Win7 version only...
Observer egger006
I'm sorry to warm up that "old" topic, but has anyone found a solution for this?
I also get these Errors:
# ** Error: (vsim-3193) Load of "./libxil_vsim.dll" failed: DLL dependent library not found.
# ** Error: (vsim-PLI-3002) Failed to load PLI object file "./libxil_vsim.dll".
I tried different versions (default 32 Bit and the 64 Bit version I found here: http://www.xilinx.com/support/answers/51972.htm ), no success.
Stefan
What version of Modelsim are you using? If you use 32-bit verson of Modelsim, please ensure you set up environment for 32-bit ISE toolset.
In windows, you can run settings32.bat in <ISE install directory>\ISE_DS.
Observer egger006
I tried running settings32.bat, nothing changes.
Yes, I am using ModelSim 32-bit.
Any other suggestions?
Looking at the error message,
it points to the current directory. See if the dll library is located at ./.
If not, you need to modify the script to point to the correct directory.
Participant simonpl
I've got a problem with "missing" libxil_vsim.dll file. The file exists under "C:/Xilinx/Vivado/2014.2/lib/win32.o/libxil_vsim.dll", but TB_name.do script calls "C:/Xilinx/Vivado/2014.2/lib/.o/libxil_vsim.dll". Each time I launch simulation, new script is generated so I can't modify it manually. I don't have "clean simulation files" checked. I use Vivado 2014.2 on WinXP 32 bit. Any ideas?
You may try to enable generate script only option in Simulation Settings. Then run the script in standalone Modelsim.
Participant simonpl
Thanks, this solution also works fine. Finally I created a folder named ".o" with the .dll file (but using cmd, because explorer cries when '.' goes as first).
