How to debug this error message
ERROR: [XSIM 43-3316] Signal SIGSEGV received.
getiing this error. Is there a workaround for this?
Re: How to debug this error message
@hulk789,
I just checked in the same code in internal build of Vivado 2016.1 and i see the same behavior.
As manusha pointed out, for now you can use the workaround of spliting the array.
but in any case, Vivado shouldnt crash. It should give proper information error and also point to incorrect portion of code to debug.
I have filed a CR#923809 on this issue.
--Syed
@hulk789
Which version Vivado are you using?
Anusheel
Helpful answer -> Give Kudos
Hi @hulk789,
Which Vivado version are you using?
Can you try with the latest Vivado version i.e. 2015.4 and see if the same error comes up?
Nupur
Nupur
i am using 2015.1 and do not have license for the latest versions
Hi @hulk789,
Can you attach your code here?
You can also try with other simulators if possible.
Nupur
Nupur
Hi @hulk789,
If you are doing port map then please modify the code some thing like this and let us know.
 instead of
inst (
      .a(b),
      .c(d)
 try
inst abc (
      .a(b),
      .c(d)
Arpan
Arpan
@hulk789,
This error is caused by a coding issue in the design.
For example: The instance name is missing in a module instantiation. See below details.
clk_if  (
      .pin_resetn(reset),
      .pin_clk156m_p(clk_ref),
     .pin_clk156m_n(~clk_ref),
     .pin_clk200m_p(pin_clk200m),
     .pin_clk200m_n(~pin_clk200m),
     .il_clk250m(il_clk250m),
     .clk156m(clk156m),
     .reset_n(reset_n)
Correcting the code like following resolves the issue.
clk_if   clk_if_inst (
      .pin_resetn(reset),
     .clk156m(clk156m),
     .reset_n(reset_n)
Which vivado version are you using? From Vivado 2013.3 and above versions you will get more information pointing to incorrect code.
--Syed
@hulk789
Looks like tool crash to me, can you share your project for us to look into this issue?
Anusheel
Hi @hulk789
This is a crash. Crash happanes when Vivado unable to handle portion of your code.
Generally speaking tool shouldnt crash and it is expected out to point to the portion of code in question.
Attach the project archive for us to test it.
Thanks,Vijay
The source of the problem is the array
wire [23:0] array [0:65535]
when i decrease the elements to 32768
i get an error : failed to compile generated c file
xsim.dir/test_behav/obj/xsim_1.c
when i decrease the elements to 16384
then there is no problem
please note that i make sure there is no undefined access in all the three above cases
hi this is the code
@hulk789,
With your code, I had an internal crash on my machine (win 7) with Vivado 2015.3:
ERROR: [XSIM 43-3294] Signal EXCEPTION_ACCESS_VIOLATION received.
I will debug it and get back to you.
--Syed
Currently there is limitation of 1000000 on variable size in vivado.
May be that could be the reason for this and when you are decreasing the array size you are not observing this issue.
As a work-around you can split the array.
@hulk789,
--Syed
Hi @hulk789,
If your query is addressed please close this thread by marking "Accept as solution" to the answer that addressed your concern.
Arpan
Arpan
