hwtodt
How to generate MMCM simulation library for logic simulation in ModelSim DE
I use ModelSim DE (64 bit windows) for logic simulation.
I use MMCM (clk_wiz_0) created from IP catalog for my design.
However, I do not know how to generate the MMCM logic simulation library.
Please tell me how to generate MMCM simulation library for logic simulation in ModelSim DE.
I will attach an MMCM specification for my design. I want to generate a logic simulation library for this MMCM ModelSim DE.
Best Regrads,
graces
You need to run Tcl command 'compile_simlib' to compile Vivado simulaiton libraries for 3rd party tools.
This can be launched from Vivado GUI Tools > Compile Simulation Libraries..., or manually run the command from Tcl console.
For its usage, type 'compile_simlib -help' for help manual.
hwtodt
Thank you for your reply.I ran the Compile Simulation Libraries. But I can not find the folder of MMCM. Which folder should I choose for the MMCM simulation library?I attached a folder list. Please tell me the folder I should select.
Best Regrards,
graces
The MMCM cell is within library unisim (VHDL) or unisims_ver (Verilog).
If you run simulation in Modelsim standalone, you need to load the library via -L switch.
If you launch simulation from within Vivado GUI, the tool will generate appropriate simulation script and start Modelsim GUI.
hwtodt
I use ModelSim standalone. And I run logic simulation using command mode in ModelSim.
I use verilog.I loaded the unisims_ver using the L switch. But there is no permission. I do not know the solution. Please tell me how to resolve the error.
I will attach unisims_v folder list and an error screen.
Best Regrards
graces
The -L (capital letter) switch is expected to be used in vopt/vsim, e.g. -L unisims_ver
You need to put the modelsim.ini that compile_simlib generates into the current simulation directory. This allows Modelsim to search the pre-compiled libraries.
I'd suggest that you run export_simulation command (or File > Export > Export Simulation) in Vivado to export a simulation script for the Vivado project targetting Modelsim. Use that as a starting point for your own one.
