Visitor tcl_balaji
How to get absolute value
I want to extract the absolute value, I use the following code, but it gives me an error.
puts "Hello World!"
set x -2
set y 3
puts $x
puts $y
puts abs($x)
puts c [expr abs($x)+$y]
Error message:
$tclsh main.tcl
Hello World! -2 3 abs(-2) can not find channel named "c" while executing "puts c [expr abs($x)+$y]" (file "main.tcl" line 7)
Re: How to get absolute value
Hi @tcl_balaji ,
You can't just type: puts abs$x
or even: puts abs $x which would make more sense syntax wise as tcl has no idea what abs means.
This is why you have to give it context using the ::tcl::mathfunc:: to let tcl know you are using a maths function.
Have a look at the link I provided in the first response.
Then you can use the following to show the absolute value of x
puts [::tcl::mathfunc::abs $x]
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
Hi @tcl_balaji ,
Try using:
and in the last line
Set c ...
puts $c
You can check out this site:
https://www.tcl.tk/man/tcl8.7/TclCmd/mathfunc.htm#M6
Best Regards
Aidan
Visitor tcl_balaji
#!/usr/bin/tclsh
puts "Hello World!"
set x -2
set y 3
puts $x
puts $y
set c [expr abs($x)+$y]
puts $c
I still can not print absolute "x"
Hi @tcl_balaji ,
You misunderstood the usage, try the following
puts "Hello World!"
set x -2
set y 3
puts $x
puts $y
set c [expr [::tcl::mathfunc::abs $x]+$y]
puts $c
Best Regards
Aidan
Visitor tcl_balaji
I want to print the absolute "x" value first.
like puts abs$x, but this statement gives an error.
Hi @tcl_balaji ,
Best Regards
Aidan
Hi @tcl_balaji ,
you can also try this format
puts "Hello World!"
set x -2
set y 3
puts $x
puts $y
puts [expr abs( $x)]
set c [expr [expr abs( $x)]+$y]
puts $c
Best Regards
Aidan
