Observer shencho
How to initialize Block RAM in BRAM Controller mode in Vivado simulation
In Vivado I want to initialize the Block RAM (Block RAM Generator 8.3 in BRAM Controller mode) before running simulation. However I cannot find information about how to do that. There are information about how to initialize BRAM in bitstream, but not in simulation. I also tried the write_mmi.tcl script but it requires me to "open an elaborated, synthesized or implemented design before executing this command," but I only want to run simulation. Please kindly help. Thanks.
Re: How to initialize Block RAM in BRAM Controller mode in Vivado simulation
Hi @shencho
When using IP integrator, the initialization in BRAM Controller Mode is done only through the MEM file. For more details, see “MEM Files” of the Data2MEM User Guide (UG658) http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/data2mem.pdf
Deepika.
Deepika.
Observer shencho
Hi Deepika,
Thanks for the reply. I already checked that document before asking. A simpler question is: How can I assign a MEM file to a BRAM? The field to assign MEM file is grayed out in Block RAM Generator 8.3 (Vivado 2015.3):
Inline image 1
Is there any TCL command to assign a MEM file to a BRAM? Or I'm completely wrong about how to use the MEM file? Thanks.
BTW, I just want to run behavior simulation.
Shencho
