mighty
How to instantiate the ddr4_model.sv in my testbench?
I've generated a vivado DDR4 SDRAM IP core and want to simulate the DDR4 memory controller with my own verilog testbench. I can instantiate the DDR4 SDRAM IP core, since there is a ddr4_0.veo file which I can use, but I can't instantiate the ddr4_model because it's encrypted and I don't know the input and output ports of it. I wonder how I can instantiate the ddr4 simulation model in my verilog testbench. Can anyone help me out? Thanks!
vemulad
Hi @mighty
Check the IP example design test bench file for instantiation of memory model. To open example design, right click on IP and choose "open IP example design"
Deepika.
