akshath@13
How to pass arguments to TCL while using xsim command?
How can we pass a arguments to the TCL file while using xsim command to simulate the source files in Vivado 2017.1
 Thanks in Advance.
Akshath Kumar
hpoetzl
Voyager
Voyager
You can use the environment to pass variables to the TCL script like this:
TEST=foo xsim --tclbatch test.tcl sim
****** xsim v2017.2 (64-bit)
  **** SW Build 1909853 on Thu Jun 15 18:39:10 MDT 2017
  **** IP Build 1909766 on Thu Jun 15 19:58:00 MDT 2017
    ** Copyright 1986-2017 Xilinx, Inc. All Rights Reserved.
source xsim.dir/sim/xsim_script.tcl
# xsim {sim} -autoloadwcfg -tclbatch {test.tcl}
Vivado Simulator 2017.2
Time resolution is 1 ps
source test.tcl
## puts $::env(TEST)
foo
Hope that helps,
Herbert
-------------- Yes, I do this for fun!
