Visitor jcangahuala
How to simulate MPSoC UltraSCALE+ in QuestaSim
I am using Vivado 2018.2 and QuestaSim 10.6c.
After compiling the simulation libraries, two fails:
* processing_system7_vip_v1_0_5 | verilog | processing_system7_vip_v1_0_5     |    1   |  0 *
* zynq_ultra_ps_e_vip_v1_0_3 | verilog | zynq_ultra_ps_e_vip_v1_0_3                  | 1      | 0 *
do you have an example using QuestaSim to simulate a system that contains an MPSoC UltraSCALE+?
reagrds
Juan
Re: How to simulate MPSoC UltraSCALE+ in QuestaSim
HI @jcangahuala ,
Can you please share the compile_simlib.log file that gets generated while compiling simulation libraries ?
Visitor jcangahuala
Trying to find the compile_simlib.log but I was not able, I was wondering if you can  provide the path where I can locate the file?
Juan
Hi @jcangahuala ,
The compile_simlib.log should be located in where you launch the Vivado session that runs the compile_simlib command.
Can you please check and make sure that you have followed the below steps to compile the simulation libraries:
Set the Questasim executable path in tools --> third party simulator Settings. Ex: /tools/dist/questa/lnx64/10.6c/bin
Then go to tools --> compile simulation libraries and check if the library location and executable path are correct. Then try compiling the libraries.
OR try using the below command from Vivado TCL console:
compile_simlib -simulator questa -simulator_exec_path {/tools/dist/questa/lnx64/10.6c/bin} -family all -language all -library all -dir {/proj/css/sravanthiB/questa_libs} -force -verbose
Please try compiling the simulation libraries in a different library location and check if you are still facing the same issue.
Thanks & Regards,
Sravanthi B
