chailei1992
How to simulate example design mentioned in PG195 with modelsim10.4c ?
I have already compiled Simulation Libraries.
When i start running simulation , there are two errors which stop the process.
i can't find these two files . What should i do next?
thakurr
Hi @chailei1992
From the screenshot of the Settings Window it looks like you are using Vivado 2017.x with which Modelsim 10.4c is not compatible version. Which Vivado version you are using? Refer below link, page 18 for compatible modelsim version with 2017.3:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_3/ug973-vivado-release-notes-install-license.pdf
Try with compatible version and let us know if you see the same error. I hope you must have followed the correct steps for simulation in third party tool standalone.
1)Compile simulation libraries.
2) Run export_simulation command to generate the simulation scripts to be used with third party tools.
3) Open Modelsim standalone and source the .do file generated.
For more information on this, please refer below link, chapter 7 page 151:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug900-vivado-logic-simulation.pdf
Rohit
Rohit
amaccre
Hi @chailei1992,
Which version of Vivado are you using?
If it is 2017.3 then you need to use ModelSim 10.6b or later and generate the compiled libraries for this version.
This is documented in User Guide 973.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
thakurr
Hi @chailei1992
Rohit
Rohit
chailei1992
your answer is very helpful, thank you very much.
