zhengyudennis1
How to start the simulation for Microblaze based system associated with .elf file (created in sdk)
Hi all,
   I just started to use Xilinx FPGA and tools recently. Is there any good tutorials for the simulation of Microblaze processor based system associated with an .elf file (created in sdk). Here, I think the elf file is like a testbech in traditional logic simulation. Thanks much for your help.
yenigal
Check if below doc helps
http://www.xilinx.com/support/documentation/application_notes/xapp1180.pdf
Satish
yenigal
Satish
zhengyudennis1
Looks good. Thanks much.
