Observer audriusa
How to test the truth table of my module
I have the module that only contains wires, something along the lines
module trivial (
  input switch,
  output led
  assign led = ~switch;
endmodule
(well, the actual code I have it is much more complex with lots of inputs and outputs, but all written in this spirit). I have a truth table (as a text file) which the module must comply. Is it possible to test with Vivado if the module is operating correctly?
I tried to click on "Run behavioral simulation" and others in Simulation item inside the Flow navigator, but it gives to me only the time line which I currently do not need. The table there shows (for the simplified example) that the switch is at "Z" and the led is at "X" - fine, but not actually helpful. I found I can "force value" of the switch, but even after I force the switch to 1, the led remains X.
How to test the truth table of the module that contains wires only? Or is the task so trivial just not supported?
Observer ryanbales
Re: How to test the truth table of my module
A simulation is exactly how you would test if it's working correctly.  Have you written a testbench to drive the inputs to specific values?  The simulator won't automatically set your inputs to every combination of values you want to test.  From your description, it sounds like the signals are undriven.  Search for Vivado Verilog testbench if you'd like help getting started.
Observer ryanbales
Observer audriusa
Understand, a simulator testbench must be written.
