How to turn off VCD file dump during simulation?
Hi All,
I am simulating design in batch mode. Can someone tell me how to turn off default VCD file dump in Vivado Simulator? I need to do this due to disk space constraints.
Thank you.
Re: How to turn off VCD file dump during simulation?
Hi @shriniket_ssrlabs,
You may try using stop_vcd command to stop capturing VCD output (equivalent of $dumpoff verilog system task).
For more information please refer the below user guide page#120
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug900-vivado-logic-simulation.pdf
Just incase if you want to limit the size you can try using limit_vcd command this will limit the maximum size of the VCD file on disk (equivalent of $dumplimit verilog task) as mentioned in below user guide:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug835-vivado-tcl-commands.pdf
Hope this helps.
Thanks & Regards,
Sravanthi B
Thanks & Regards,
Sravanthi B
