How to use xsc with libraries?
I have some DPI code which I compile into a .so library. My DPI library depends upon some other library so I would like to pass -L,-l, and -Wl,-rpath (or use LD_LIBRARY_PATH) to the linker.
I have written a small C program to call my DPI functions using the .so file which is working fine.
It seems like xsc is suited for either passing C source files or already compiled object files, which then generates dpi.so.
Is it possible to skip the entire xsc altogheter as long as I use the Vivado supplied gcc?
If so what options to I pass to xelab to pass the above options to the linking stage?
If not how can I do this with xsc?
BTW: This is on 2018.2 on Linux.
Re: How to use xsc with libraries?
I just tried to skip xsc.
I simply used --sv_root to point to the location of my library, and --sv_lib to my own library. It seem to work fine.
