How to write the value of a signal in a file in signed decimal or hexadecimal formate using verilog or vhdl
I want to write the value of a signal in a file in signed decimal or hexadecimal formate. so any one help me in this.
thanks
Re: How to write the value of a signal in a file in signed decimal or hexadecimal formate using verilog or vhdl
Hi @d2d
Using verilog
f = $fopen("output.txt","w");
$fwrite(f,"%d\n", <wire/reg name>);
 Formatting:
%d or %D for decimal
%h or  %H for hexadecimal
Bharath
Please mark the Answer as "Accept as solution" if information provided addresses your query/concern.
For VHDL, example:
architecture log_to_file of FILE_LOG is
file l_file: TEXT open write_mode is log_file;
begin
while true loop
write(l, str(x1)&" "& hstr(x2)& "h");
writeline(l_file, l);
end loop;
Ensure to add use std.textio.all;
Debraj
in addition to $fwrite you can also use $display and redirect the output to a file too. $fwrite & $display use a formatting string similar to printf in C so %d is is for decimal & %x is for hex.
