How to write the value of signal in signed decimal or hexadecimal formate in a file using verilog or vhdl.
I want to write the value of a signal in signed decimal or hexadecimal formate using verilog or vhdl in file for verifying it in matlab. so any one help me in this regard.. thanks
Re: How to write the value of signal in signed decimal or hexadecimal formate in a file using verilog or vhdl.
if you are using Verilog, you can use system functions like below in example
_____________
module top();
reg [3:0] r1;
integer ch;
initial
begin
    r1 = 4'b1010;
   ch = $fopen("abc", "w");
   $fdisplay(ch, " r1 = %b\n", r1);
    $fdisplay(ch, " r1 = %h\n", r1);
    $fdisplay(ch, " r1 = %d\n", r1); // use this for signed decimal
    $fdisplay(ch, " r1 = %o\n", r1);
    $fclose(ch);
end
endmodule
_______________
For VHDL, you can have something like this
___________
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use std.textio.all;
entity top is
end entity top;
architecture arch of top is
signal s1 : unsigned(0 to 3) := (others => '1');
begin
process
variable sttr : line;
file dataout : text open write_mode is "abc";
begin
    write(sttr, to_integer(s1));
   writeline(dataout, sttr);
    wait;
end process;
end;
________
--dhiRAj
Do you mean in the testbench or during simulation?
Sikta
_____________
module top();
reg [3:0] r1;
integer ch;
initial
begin
    r1 = 4'b1010;
    $fclose(ch);
end
endmodule
_______________
___________
library ieee;
use std.textio.all;
entity top is
end entity top;
begin
process
begin
    wait;
end process;
end;
________
--dhiRAj
In test bench.
Yes in testbench or is design unit where the signals are declared.
